Create your own XnViewMP user manual
Post by michel038 »
As the title suggests, anyone can generate their own XnViewMP user manual.
The method involves using an AI (ChatGPT, Gemini, Grok, etc.).
However, to get an accurate and detailed response, you need to limit your question to a specific topic.
The forum section the AI should use is “MP general support”
In the following example, here’s what you can ask the AI about "Overlay Icons"
There is some scattered information in the XnView forum about "overlay icons"
You can use a search engine to find the links for topics about "overlay icons" in the forum.
Do not follow links that lead outside the forum.
Some of the informations are outdated, so please use only the most recent information that replaces it.
Then write a short user guide about this subject.
The url of XnViewMP forum is https://newsgroup.xnview.com/viewforum.php?f=82
Of course, any other subject can be covered in a new chapter of your user guide—simply replace the words "overlay icons" in this example with terms that suit your needs.
ChadASimmons
Re: Create your own XnViewMP user manual
Post by ChadASimmons »
Great prompt, thanks for sharing.
I used the prompt with Gemini and "face tag" and it produced some very useful information.
