Using 1.10.5
When more than 999 images are selected in browser window the Assigned pane does not show any cateories
and there is no indication that an internal limitation has been exceeded.
Limit to number of selected files
Re: Limit to number of selected files
how do you see that. i've tried with 4000 files, and assigned is correct
mkc73
I go to a folder with a 1000 images or more. Click on first image, SHFT click on last image. Assigned isn't populated. i gradually reduce the number of files selected. At 999 files Assigned is populated.
This problem is supposed to be fixed in XnView MP 1.11.1. Please check and confirm the bug fix here.
