Please make the fine dividing lines between the three sections of the sort order display more prominent, either a bit wider or a darker colour.
Clear display of the section dividing lines makes clear that three selections are required to define a desired sort order.
'View > Sort order' options display
Re: 'View > Sort order' options display
separators are global
some tuning could help, eg:
- Light, Dark, Black
- add extra 5px for top/bottom margin
- Black
- change color to grayish
When I last saw the sort order drop-down -- before the recent changes -- the separation lines between the sections seemed quite feint and easily missed by someone in a hurry not familiar with setting a desired sort order...
A global rather than a Linux issue, I assume.
Edit: Full HD 14" laptop screen, visibility might be somewhat better on higher-resolution screens.full hd screen
