Modified date
Pepelu
Modified date
Post by Pepelu »
Question, warning, this may sound strange.
Is there a limit to how far back you can go to set the modified date?
I am scanning some old photos and trying to set the dates, taken and modified, as close to the time and date that the pictures were actually taken.
In this case is 6/1/1970. I have changed the timestamp for all fields to January 6th 1970, but the File modification date sets itself to 1/1/1980. The rest of the date fields are correctly updated to 6/1/1970
Re: Modified date
Post by michel038 »
File creation and modification dates are determined by the operating system (Windows, macOS, etc.). Most operating systems use an internal timestamp where “0” corresponds to January 1, 1970, so it's impossible to use previous dates.
You can use 'EXIF dates' to set the correct date for older photos.
Pepelu
Re: Modified date
Post by Pepelu »
Thanks, I didn't know that.
In my case it must be 1/1/1980 for some reason.
jkm
Re: Modified date
Post by jkm »
Don't try to set the file modification or creation times for this purpose. One, it's inappropriate, and two, your ability to set them is operating system dependent. You don't say what OS you're using here, but I presume Linux from your earlier posts. Let the file modification date be updated to a current timestamp for backup considerations.
You should modify the EXIF date fields. Here is a guide to help you understand them, since they are referred to by different names in different circumstances. The EXIF Specification has official names, and these names may be used in other applications. Exiftool, an industry standard, uses different names which are also widely echoed in different applications. XnViewMP has its own names. Confusing, but that's just the way it is.
Exif Specification        Exiftool           XnViewMP        Purpose
DateTime                  ModifyDate         ModifyDate      Date/Time the file was changed
DateTimeOriginal          DateTimeOriginal   DateTaken       Date/time when original image was taken
DateTimeDigitized         CreateDate         DateDigitized   Date/time when the image was stored as digital data
So as you can see, sometimes two of them agree, but all three never match. Generally, disagreeing with the spec is bad. It's also not brilliant to disagree with Exiftool, since it is so widely used and respected. But, the DateTime field is poorly named in the spec. And the CreateDate name was a poor choice by Phil for Exiftool (but he has used it so long, it will not change now). With XnViewMP, Pierre settled on names that best convey what the field is actually supposed to be used for. So the names used by XnViewMP are from that perspective "best" but unfortunately therefore disagree with widely accepted authorities.
Digital cameras always set DateTimeDigitized=DateTimeOriginal.
The reason for having two fields, is you can set one (DateTimeOriginal) to when the original image was taken on film, and the other (DateTimeDigitized) to when the film image was scanned into digital storage (perhaps years later).
The DateTime/ModifyDate field allows for tracking when the image was subsequently changed without touching the other two.
Operating System Filesystem timestamps are different. For example, if you took a JPEG and resaved it as WEBP, the above three fields should be preserved in the WEBP image, but the filesystem dates should be current, because it is a new file.
So for modifying the EXIF fields, if you use the Edit EXIF dialog in XnViewMP, you will not encounter any problem in setting the dates as necessary; even dates before 1970 are allowed.
Hopefully this helps...
Pepelu
Re: Modified date
Post by Pepelu »
Thanks, great explanation.
I use the timestamp on the pictures for sorting the files. Within XnView there is no problem as there many different ways to sort and you can always find the most suitable one. I am thinking of other apps or just different file managers that I may use to browse through the photos when not on my computer. In many cases, the date that the system uses for sorting is what they call modified date, this is why I use the change time stamp functionality.
Also, sometimes, for current digital photos, the time setting on the camera may be wrong and I just want to adjust to the real time and date for the photo.
I don't use the backup functionalities to safeguard my pictures, so I am not worried about that.
jkm
Re: Modified date
Post by jkm »
You might want to check if you file manager can sort by the EXIF date fields; Windows can. Or you could rename the files to include Date Taken as part of the name, so that sorting by name effectively sorts by date.
Incorrect camera times are not a reason to change filesystem times, because you can change the Date Taken field (or any other EXIF date field) just as you can the filesystem date.
You have to suit yourself of course, but schemes that depend on OS-maintained/modified mutable fields like file modification date usually end in disappointment.
Good luck...
Pepelu
Re: Modified date
Post by Pepelu »
Thanks for your suggestions.
Maybe modified date is not the best option for sorting files. I am starting o play with the face tag option and that updates the file modification date, so I will think about this a little further. i will check what alternatives I have outside XnView that will work for me.
Changing the name is not an option anymore. Thanks.
Another reason why I was using this field is because it is the first one that appears on the change timestamp option.
