PDF and Ghostscript
nicolleen
PDF and Ghostscript
Post by nicolleen »
I have not found a solution in your forum. I've been using XnView for decades. I've got the newest version of MP and when I want to view a pdf file, I get told, I need ghostscript 64.
First I tried updating the portable ghostscript from PortableApps.com, but it isn't seen by XnView.
Then I installed the installed version of ghostscript 64 on the laptop (new, Lenovo, Win11) and restarted the whole laptop, but to no avail. I still get the popup instead of the file viewing.
What am I missing? Thanks...
Re: PDF and Ghostscript
so you have downloaded this file?
nicolleen
Post by nicolleen »
Yes!
nicolleen wrote: Sun Apr 05, 2026 8:55 pmYes!
please change debug=2 in xnview.ini and send me the logs when you select a pdf file
Ben2148
Post by Ben2148 »
Hello
I have the exact same problem with XnConvert.
I have XnConvert and Ghostcript installed on my W11 computer.
I'm trying to convert a PDF file into JPG files, 1 JPG per page.
But when I add a PDF file and try to convert it, I got the error "not a image"
I don't know what to do.
Thank you for your help.
There have in the fairly recent past been at least two cases where new GS versions have not been compatible with existing xnview software versions, requiring current xnview software versions to be updated for compatibility. So if everything else seems to be in order, it might be worth testing compatibility with immediately previous Ghostscript downloads.
jkm
Post by jkm »
I remember using GhostScript back in the 80's…
It was a pain in the neck then, too.
