I am surpriesed that the DNG's are note displayed as I stored them. I did some corrections to the photos and stored them as DNG. And it seems that XnView shows them without the corrections - and not the included JPG-file.
Is there a possibility to change that or what I'm doing wrong?
DNG's are strangely displayed
Re: DNG's are strangely displayed
Could you send me a sample?bob3150 wrote:I am surpriesed that the DNG's are note displayed as I stored them. I did some corrections to the photos and stored them as DNG. And it seems that XnView shows them without the corrections - and not the included JPG-file.
No please [email protected] (remove -nospam)Anonymous wrote:I have sent you the information to <!-- removed //--> with the title "DNG's are strangely displayed" and the size approx. 7MB. Hopefully you can do something with it.
bob3150
But it is not possible to send an mail to this account.
This Message was undeliverable due to the following reason:
Your message was not delivered because the destination computer was
not found. Carefully check that it was spelled correctly and try
sending it again if there were any mistakes.
It is also possible that a network problem caused this situation,
so if you are sure the address is correct you might want to try to
send it again. If the problem continues, contact your friendly
system administrator.
Host xnview-nospam.com not found.
The following recipients did not receive this message:
<[email protected]>
Please reply to <[email protected]>
if you feel this message to be in error.
The following attachments have been removed from the bounce message: XnView-Thumbnail.jpg, Bridge-Thumbnail.jpg, CRW_5080.dng
REMOVE -nospam in the email accountbob3150 wrote:But it is not possible to send an mail to this account.
This Message was undeliverable due to the following reason: Your message was not delivered because the destination computer was not found. Carefully check that it was spelled correctly and try sending it again if there were any mistakes. It is also possible that a network problem caused this situation, so if you are sure the address is correct you might want to try to send it again. If the problem continues, contact your friendly system administrator. Host xnview-nospam.com not found. The following recipients did not receive this message: <[email protected]> Please reply to <[email protected]> if you feel this message to be in error. The following attachments have been removed from the bounce message: XnView-Thumbnail.jpg, Bridge-Thumbnail.jpg, CRW_5080.dng
