Image icons.
SoCu
Image icons.
Post by SoCu »
Hi, how do I set different icons for images, depending on the file type?
Right now, they all have the same icon, and it's hard to tell if a file is a JPG or a PNG because they all look the same.
I’m not sure if this can be changed within the app; I’ve been looking for a setting to configure this, but I haven’t been able to find it.
Thanks.
Re: Image icons.
icons are in
..\XnViewMP\FileIcons
if you want to add extra filetypes/icons - read
XnViewMP - integration - file association
SoCu
Re: Image icons.
Post by SoCu »
Thanks, user0. Where can I find more icons to put in that folder? I see that some icons are missing. I don't know why I haven't opened that folder before, or even knew the icons were there, but some of them have been deleted.
