When entering the image split settings, you'll see the Create button is the default, but it has the following issues:
1) You can't press Enter directly; you have to use the mouse to click Create.
2) To use Enter to execute Create, you need to move the mouse cursor to the count input box.
3) The mouse cursor cannot select to modify the path; you must use the browser button.
v1.10.5 Image Split Settings Button Malfunction
alee001
Re: v1.10.5 Image Split Settings Button Malfunction
What do you means?
alee001
Sorry, I meant the path box cannot be entered/pasted for editing.xnview wrote: Tue Apr 14, 2026 9:13 amThanks to your detailed description I can reproduce the problem.
What do you means?
yes you need to use the buttonalee001 wrote: Tue Apr 14, 2026 1:11 pm Sorry, I meant the path box cannot be entered/pasted for editing.
alee001
That's the problem. If you can't paste or edit custom paths, then the path box loses its function and becomes a display box?
This problem is supposed to be fixed in XnView MP 1.11.1. Please check and confirm the bug fix here.
