Hello together,
I've noticed that in my roaming-directory (Win 10)
c:\Users\myuser\appdata\Roaming\XnView\
there is the xnview.db, which is about 16gb large.
Unfortunately, I am running out of space on my c; - device. Is there a chance to move this db to another place, e.g. d:abc\ ?
Perhaps an entry in the registry? Or another way? Most important is, to remove the xnview.db from c:
Thanks for possible answers
tropf
Move XnView.db to somewhere else?
tropf
Re: Move XnView.db to somewhere else?
Well, I've found the solution:
Menu > Options > Browser > Thumbnails > Cache,
Use folder section: set custom + path for xnview.db
This is indeed worklng and solves my problem.
