Why isn't it possible to use drop shadow with other backcolo
bob3150
Post by bob3150 »
Why isn't it possible to use drop shadow with an other background color in thumbnail view?
And why I can't change the strange light brown color of image background text (because Videos for example do not have this problem) in thumbnail view?
Re: Why isn't it possible to use drop shadow with other back
bob3150 wrote:Why isn't it possible to use drop shadow with an other background color in thumbnail view?
currently work only with white...
You must disable color by file type
bob3150
Post by bob3150 »
Thank you for the tip - that help me a lot
Do you think that you implement the drop shadow for custom colors - will be very nice
bob3150 wrote:Thank you for the tip - that help me a lot
Yes perhaps in a future version :-)
bob3150
Post by bob3150 »
Hopefully soon :D
