Customisation request: Reduce number of output formats
Gwillewyn
Post by Gwillewyn »
I never use any output formats besides the usual "same as original", png, webp, jpg, and once in a while gif and bmp, but I do change between them often. It would be a great convenience if I could trim down the list of output formats so that I don't have to scroll up and down, and (way too often, because I have the coordination of a drunk chimp) miss-click.
I'd love to either:
  • Be able to edit the list and remove formats I never use
  • Have the last/most used 5 format show on top of the dropdown
  • Have the only most common formats on the dropdown with an [other...]-option at the bottom.
marsa
Re: Customisation request: Reduce number of output formats
Post by marsa »
This is an existing option. Go to "Settings" tab, and then look for "Load format settings..." at the bottom left. In the newly opened window you can exclude the formats that you don't need.
Gwillewyn
Post by Gwillewyn »
Thank you so much! I don't know how I missed that.
You've made my life just that little bit better.
