1.10.5: MP4 preview display issue (all videos distorted/glitched)
A_I0328
Post by A_I0328 »
App Version: XnView MP 1.10.5 - 64 bit
OS: [Windows 11] - 64bit
Description:
Since updating to version 1.10.5, when previewing MP4 files, the video does not render correctly. Regardless of whether it is the layout preview or the full-screen preview, all video files appear distorted as shown in the attached image.
Effect: The video preview is unusable as the visual output is corrupted/incorrect.
Open the application and navigate to a folder containing MP4 files.
Select any MP4 file to view it in the layout preview.
Switch to full-screen preview mode.
Note that in both cases, the video output matches the attached screenshot instead of playing normally.
Actual behaviour (bug):
All MP4 videos show a glitched or incorrect visual output (see attached image) in both the layout and full-screen preview modes.
Expected behaviour:
Videos should be displayed correctly and clearly in both the layout preview pane and the full-screen view.
Re: 1.10.5: MP4 preview display issue (all videos distorted/glitched)
all mp4?
A_I0328
Post by A_I0328 »
I tested both MP4 and AVI files, and the same issue occurred with both.
It seems that videos in general aren't working.
johnsmith88
Post by johnsmith88 »
I am getting this exact issue as well where it hangs with that weird "arrow" shape when opening an mp4 video from a Google Pixel 8. It's really irritating when hitting Next when going through a sequence of files, then you hit on a video and the whole thing hangs.
johnsmith88 wrote: Mon Aug 10, 2026 3:52 pm I am getting this exact issue as well where it hangs with that weird "arrow" shape when opening an mp4 video from a Google Pixel 8. It's really irritating when hitting Next when going through a sequence of files, then you hit on a video and the whole thing hangs.
same with 1.11.5?
johnsmith88
xnview wrote: Fri Aug 14, 2026 9:49 am
same with 1.11.5?
Yes. Thanks.
