Merge Folders feature
venik
Post by venik »
Would it be possible to introduce a “Merge Folder” feature?
Use case:
yyyy_mm_dd
yyyy_mm_dd+1
yyyy_mm_dd+2
When working with the same event spread across multiple days,
I’d like to merge everything into a single folder (yyyy_mm_dd).
I noticed that Batch Convert could be used as a workaround, but it’s not ideal
(it copies files, on the contrary I would expect move and delete empty folders).
Thank you for considering this feature,
Vincenzo
Re: Merge Folders feature
1. move all folders into same parent folder
2. open this parent and press 'Show files in subfolders' button
3. Ctrl+A, Ctrl+X
4. Ctrl+V wherever you need
