1.10.5: SEGV crash when i switch to a webm file
postcd
Post by postcd »
XnView: MP 1.10.5
OS: Linux Ubuntu 24 (LTS) with KDE, Wayland
When I am viewing a image (i have tried png, jpeg, gif), and then use mouse wheel to switch to a next file, which is webm, wmv or mp4 video (only tested these), then the app is repeatedly crashing.
1. Download/check sample data at https://drive.proton.me/urls/JHPZCBVGXG#bqDEXaaPAmcj
2. open that png image, full screen, in 2 seconds use mouse wheel to switch to a next file (webm), it crashes on my end.
Linux user, .deb package. Use private services like Proton.me, not surveillance services like Google, Meta.
Re: 1.10.5: SEGV crash when i switch to a webm file in a full screen mode
do you have the problem with only webm or any video files?
postcd
Post by postcd »
xnview wrote: Thu Apr 30, 2026 7:27 am do you have the problem with only webm or any video files?
Also other files, i have tried to move from .gif to wmv and mp4 and both crashed. Fullscreen does not matter, it crashes in regular view too.
if you use shortcuts or menu entries to go to next file, same issue?
postcd
Post by postcd »
xnview wrote: Sat May 02, 2026 8:13 am if you use shortcuts or menu entries to go to next file, same issue?
Yes, it crashes also when i click arrows in the toolbar(and in a full screen view) or use PgUp/PgDown key shortcut.
could you change debug=2 in xnview.ini, and send logs from terminal?
postcd
Post by postcd »
xnview wrote: Wed May 06, 2026 7:42 am could you change debug=2 in xnview.ini, and send logs from terminal?
Yes, ~/.config/xnviewmp/xnview.ini had debug=0 and here is output of debug=2. Thank you
Wayland, Plasma 6.6.4.
could you try to set
QT_XCB_GL_INTEGRATION=xcb_egl
postcd
Post by postcd »
xnview wrote: Mon May 11, 2026 6:43 am could you try to set
That does not prevent crash: https://justpaste.it/k1kh8
If you have been interested specifically in debug=2 output, then it is here: https://justpaste.it/mq6m0
postcd wrote: Mon May 11, 2026 7:27 am
could you try the beta version
postcd
Post by postcd »
xnview wrote: Mon May 25, 2026 8:33 am could you try the beta version
No, the Linux link in 1st post points to a 404 page... Windows link works, but i am not using Windows.
postcd wrote: Mon May 25, 2026 2:08 pm
Please try again
postcd
Post by postcd »
Yes, it does NOT crash under that Linux beta version. Thank you for the fixes. :bugfixed:
