RC3: toolbar and status bar problem
ali
Post by ali »
my toolbar and status bar disappear randomly... /updated/ in relation to another problem - double-click to get from fullscreen (start view in fullscreen option enabled) to browser isn't working. the problem with toolbars comes after pressing escape (with double-click not working) and starting xnview again. i'm sure it's a bug
XnView 1.82 RC3
Re: RC3: toolbar and status bar problem
ali wrote:my toolbar and status bar disappear randomly... /updated/ in relation to another problem - double-click to get from fullscreen (start view in fullscreen option enabled) to browser isn't working. the problem with toolbars comes after pressing escape (with double-click not working) and starting xnview again. i'm sure it's a bug
Do you have a way to reproduce it always? Perhaps send me your .ini?
ali
Post by ali »
got it. it seems to happen when you're impatient and try to double-click before the picture fully loads...
marsh
Post by marsh »
ali wrote:got it. it seems to happen when you're impatient and try to double-click before the picture fully loads...
Right. Whenever picture is interrupted while viewer is trying to display it, missing GUI parts occur (No title bar, tool bar, status bar). It also makes mouse-cursor invisible.
When you load a picture in the viewer?
ali
Post by ali »
it seems to be just fullscreen problem
ali
Post by ali »
i hope this will be fixed soon. it's really annoying :?
ckv
Post by ckv »
Ok after hard time trying to repo this porblem, I got it. And I can reproduce the bug.
Reproduce:
- open you biggest image file (try jpg 2000 files if nothing else "works" :wink: ) in "quick" fullscreen (midle click in browser)
- double-click to close the fullscreen before the image is loaded
= Sometimes the tab bar, tool bar or status bar disappears
ali wrote:I hope this will be fixed soon. It's really annoying.
How often this happens to you? I find the bug very hard to reproduce and closing the fullscreen before the image is loaded is something what I wouldn't do very often in normal use.
Edit: I meant tab bar not title bar
ckv wrote:...
Thanks, ckv for your description how to reproduce. Perhaps the problem depends on computer speed and/or graphic card, too.
ali
Post by ali »
well... i've got old duron /1200/ so the loading time for larger pictures is about 2-3 seconds at high quality. it happens everytime i double click /i want browser/ before *any* picture fully loads. i've got "start view in fullscreen" option enabled. when i click on wrong picture from windows explorer or just want to go from fullscreen to browser immediatelly i won't wait needless 3 seconds for the loading process to complete. i think nobody won't...
ckv
Post by ckv »
helmut wrote:Thanks, ckv for your description how to reproduce. Perhaps the problem depends on computer speed and/or graphic card, too.
No I doubt that it haves anything to do with graphic card since the big isn't a "graphical error" (like you can easily think when you read the bug descriptions) When the tab bar, tool bar or status bar disappears, those are just disabled in the view menu. So the GUI elements are not there, in a normal way. :mrgreen:
And by the way. The title bar never really disappears, even though I wrote so. Sorry about that.
