Support for gltf material files
Foxyrick
Post by Foxyrick »
I frequently work with PBR materials in gltf format. The gltf file itself is simply a text file that can be parsed to find the texture names, which are usually in a given sub folder.
I'm not suggesting turning XnView MP into a 3D renderer (although that would be ideal - I can dream :wink: ). Showing just the base texture from the gltf files would be sufficient in most cases.
