1.11.1 - browser - catalog filter - Check ignores catAlignRight
Bugs which are supposed to be fixed in the next test version (not available yet)
XnViewMP 1.11.1
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Browser - filelist
to reproduce
1. add [Browser] catAlignRight=true into xnview.ini
2. open folder with files in Browser
3. Check any file
4. open Catalog filter pane
Special items > Check will have counter next to it instead aligned to the right
Related
Re: 1.11.1 - browser - catalog filter - Check ignores catAlignRight
This problem is supposed to be fixed in XnView MP 1.11.2. Please check and confirm the bug fix here.
it works, but there is issue with updating Check counter in Catalog filter pane
it does not update immediately after changing file's Check state and moving focus from file
it requires either hover cursor over Catalog filter pane or reopen Browser tab
there is no such issue with Check counter when catAlignRight is false (other counter not affected)
reopened
