Hey All
Coming from Adobe Bridge... using XnView MP on Windows 11.
XnView has been great in every way.
The only thing I can't figure out is that I am used to having a project folder that has design files like Photoshop & Illustrator as well as additional folders.
I prefer to sort by modify date with files first, then folders.
I can't seem to figure that out in XnView... with folders always shown first, then files... not the end of the world by any means..
Am I missing a setting.. or custom sort?
Thanks!
Dave
Sorted files before folders?
Re: Sorted files before folders?
currently not possible to sort files before folders
jkm
Or utilize the Folders pane to show/navigate folders and don’t show folders as icons in the browser at all. Then you just have the image files by themselves.
_david
Thanks for the fast responses!
Pierre... thanks for the great application.
