Plugin not working
bob3150
Plugin not working
Post by bob3150 »
I tried to use the Whitebalance plugin from theimagefactory and when starting the plugin the following message is comming:
"The plugin encountered an invalid image mode. Please make sure the image mode is set to RGB, and R, G, and B channels are selected in the channel palette"
Do somebody know what to do in such a case?
Re: Plugin not working
bob3150 wrote:I tried to use the Whitebalance plugin from theimagefactory and when starting the plugin the following message is comming:
Is it possible to have this plugin?
Post by Guest »
Yes, you can downlad the Testversion from http://www.theimagingfactory.com/download/
Choose 1. Color Correction, 2. White Balance
