Update: don't even need to restart program just open image in full screen then close it by pressing Escape key (not Enter key) and then open again full screen then same problem happens as described in first post.
FKCapitalism2 wrote: Fri May 01, 2026 2:15 pm
jkm wrote: Fri May 01, 2026 5:44 pm
Check your settings in Settings:View:Fullscreen Do you have show info on or off?
Or View:Info, is Always show in fullscreen enabled?
What this options do Settings > View > Fulscreen > Show Info
After messing with that i seems to have more lag now.
I have both disabled,
P.S. i don't need info to always show in full screen.
i can't reproduce, please send us your xnview.ini
Attached.
