XnView: MP 1.10.5.0 x64
OS: Windows 64bit
Failure to update as Exiftool.exe still running
Effect: As it is a non-interactive update the error code doesn't just kill the running instances or explain what occurred. However the logfile does
display what was the cause.
1. Have xnview exiftool.exe still running
2. execute: winget update XnSoft.XnViewMP
3. Exists with code 5
Starting package install...
You cancelled the installation.
Installer failed with exit code: 5
CMDLINE LOG
DEV winget update XnSoft.XnViewMP
Found XnView MP [XnSoft.XnViewMP] Version 1.11.2.0
This application is licensed to you by its owner.
Microsoft is not responsible for, nor does it grant any licenses to, third-party packages.
Downloading https://download.xnview.com/old_version ... in-x64.exe
██████████████████████████████ 56.5 MB / 56.5 MB
Successfully verified installer hash
Installer log is available at: C:\Users\john\AppData\Local\Packages\Microsoft.DesktopAppInstaller_8wekyb3d8bbwe\LocalState\DiagOutputDir\XnSoft.XnViewMP.1.11.2.0-26-05-01-17-16-10.log
DEV ps exiftool
NPM(K) PM(M) WS(M) CPU(s) Id SI ProcessName
9 20.42 7.96 2,402.84 37388 1 exiftool
10 131.81 8.28 2,401.03 37644 1 exiftool
DEV ps exiftool | kill
Successfully installed
WINGET INSTALL LOG
2026-05-01 17:16:26.267 Installing the file.
2026-05-01 17:16:26.275 Successfully installed the file.
2026-05-01 17:16:26.275 -- File entry --
2026-05-01 17:16:26.275 Dest filename: C:\Program Files\XnViewMP\AddOn\exiftool.exe
2026-05-01 17:16:26.275 Time stamp of our file: 2026-02-23 09:46:04.000
2026-05-01 17:16:26.275 Dest file exists.
2026-05-01 17:16:26.275 Time stamp of existing file: 2026-02-23 08:46:04.000
2026-05-01 17:16:26.275 Installing the file.
2026-05-01 17:16:26.278 DeleteFile: The existing file appears to be in use (5). Retrying.
2026-05-01 17:16:27.283 DeleteFile: The existing file appears to be in use (5). Retrying.
2026-05-01 17:16:28.292 DeleteFile: The existing file appears to be in use (5). Retrying.
2026-05-01 17:16:29.303 DeleteFile: The existing file appears to be in use (5). Retrying.
2026-05-01 17:16:30.315 Defaulting to Abort for suppressed message box (Abort/Retry/Ignore):
An error occurred while trying to replace the existing file:
DeleteFile failed; code 5.
Access is denied.
2026-05-01 17:16:30.315 User canceled the installation process.
2026-05-01 17:16:30.315 Rolling back changes.
2026-05-01 17:16:30.347 Starting the uninstallation process.
2026-05-01 17:16:30.347 Deleting file: C:\Program Files\XnViewMP\dav1d.dll
2026-05-01 17:16:30.349 Uninstallation process succeeded.
2026-05-01 17:16:31.852 Deinitializing Setup.
2026-05-01 17:16:32.310 Log closed.
UTC
Re: winget update XnSoft.XnViewMP
after a crash?
jkm
The exiftool.exe file is in use because it is running (probably because of a crash or abnormal app termination) and therefore can’t be replaced.
Kill the process and then run the install.
UTC
Likely after a crash, I cannot recall if the application crashed last time I used it.
The xnview application was not running when winget was invoked.
jkm
But the exiftool process was.
Kill the exiftool process before running the install.
