Subject: 1.11.2: XnView MP does not read xmp files modified by Lightroom
PhotoDyaz
Post by PhotoDyaz »
XnView: MP 1.11.2 - 64-bit
OS: Windows 10 - 64-bit
XnView MP does not read data from xmp files modified by Lightroom, including GPS data.
Effect: Data in xmp files is not read.
1. Select a NEF file that has an XMP file edited by Lightroom, for example keywords, GPS data, and stars.
2. The data is not visible in XnView MP.
3. Modify from XnView MP Metadata->Rating and enter any star values.
4. Refresh with F5.
5. Now the data as keywords is visible, but the GPS data is still being taken from the nef file instead of the xmp file.
6. Data modified by XnView is read by Lightroom.
7. If the data is modified again in Lightroom, it is not displayed again and we return to point 1.
Actual behaviour (bug): XnView does not read XMP files edited by Lightroom :bug:
Expected behaviour: Compatibility between Lightroom and XnView xmp files.
Re: Subject: 1.11.2: XnView MP does not read xmp files modified by Lightroom.
Please send a xmp file?
jkm
Post by jkm »
Photodyaz, please check the following:
1. Do you have Settings:Metadata:"Update catalog when file is modified outside" enabled? Do you have everything under Import enabled on that same page?
2. If you browse into the folder with the modified sidecar (xmp) file AFTER the file was modified (browse to a different folder then browse back if necessary) does that affect if the updated metadata is read?
3. Select the modified files, then do Metadata->"Update catalog from files+options", and select master/sidecar & use modified files only, then click update. If the file name is then NOT listed in the log, that would indicate the modification is not detected (no new modification since the previous metadata update in XnViewMP). Check the filesystem modification date of the sidecar file and confirm the updated contents.
Check the new features guide to ensure you know how the functionality works for metadata changes:
viewtopic.php?p=213646#p213646
PhotoDyaz
Post by PhotoDyaz »
jkm wrote: Sat May 02, 2026 5:11 pm Photodyaz, please check the following:
1. Yes I have Settings:Metadata:"Update catalog when file is modified outside" enabled.
2. If I copy the files in a new folder and browse into de new one and refresh and is the same.
3. The data is there. The problem is that the data isn't read until the XMP files are modified by XnView. This also happens with the catalog disabled.
Please tell me how to send you an xmp file.
jkm
Post by jkm »
What about the second part of #1?
What about #3, the modification date on the sidecar file? I mean after the LR changes, but BEFORE you try any modifications in XnViewMP.
You post your file somewhere and provide a link here, you can attach it to a post, or email it to contact at xnview.com
PhotoDyaz
Post by PhotoDyaz »
Hello.
#1. Yes I have everything under Import enabled on that same page.
#3. Nothing happens when I perform step #3. The file remains unchanged, with the same time/date. The only difference is when I modify the star rating and refresh with F5. But even then, it still doesn't read the GPS data from the XMP file. I've attached images showing the steps and the XMP file. I'm using Spanish. I believe the same issue occurred with the previous version of XnView MP, version 1.10.
Files:
https://1drv.ms/u/c/e36e6f3f7b286db1/IQ ... s?e=Oml2MZ
jkm
Post by jkm »
If you are saying Lightroom is not updating the filesystem file modification time on the sidecar file, that is a problem.
PhotoDyaz
Post by PhotoDyaz »
This also actually happens with xmp files created for the first time by Lightroom.
jkm
Post by jkm »
Sorry, but 2 months have gone by since your last post and your link has expired and new software versions have been released.
Please try your issue with the latest version, 1.11.5 viewforum.php?f=115
If you still want this looked at, your responses will have to be more timely, and you'll need to provide:
1. Before and after versions of the XMP file, with a rating (star) change made by Lightroom, that XnViewMP doesn't process.
2. Before and after screenshots of Windows explorer, showing the XMP file in Details view, showing the Date Modified column.
3. Screenshot of Settings:Metadata
4. Screenshot of Settings:Metadata:Sidecar
5. The NEF file
So that's a total of 4 screenshots, 2 xmp files, and the NEF. You can provide a link to a ZIP file.
Thanks...
PhotoDyaz
Post by PhotoDyaz »
Hello.
It seems to be a problem on my end that it's not working.
I have no interest in remaining on this forum.
Please delete my account.
Thank you.
