After the last update the cutting feature of XnViewMP is not working any more.
The ikon appears on the task line but after clicking on it the curring feature, means the window drwing that limites the cutting, is not working.
Can you help me with this?
Operating System: windows11
Antivirus Software: Avira
Thanks a lot and kind regards
Wolfgang Flügel
XnView curring featur
Re: XnView curring featur
Selecting an area and clicking on 'Crop', its not working?
jkm
The feature seems to work fine.
Check your settings in Tools->Settings:Interface:Mouse
Make sure you have one button/modifier set to "Make Selection" and use that.
