1.11.2 (MacOS) last file is selected automatically in fullscreen mode
mpbac
Post by mpbac »
XnView: 1.11.2 - 64 bit
OS: Mac
The last file is selected automatically in fullscreen mode
Effect: the fullscreen view does not show the current file, always shows the last file in the folder.
1. Open any folder, select any file
2. Click the Enter key or double click whatever to enter the Fullscreen view.
3. You will see only the last file i the list.
Expected behaviour: the Fullscreen view show the currently selected file.
Re: 1.11.2 (MacOS) last file is selected automatically in fullscreen mode
I'm not able to reproduce, please send us the xnview.ini
mpbac
Post by mpbac »
I zipped and attached the xnview.ini here.
- start XnView in a folder with 2 image files
- select first file, ENTER
- Tab is opened with this file
you have not that?
