How many programs are listed as installed?
SoCu
Post by SoCu »
Hi, I was testing a program uninstaller, and I came across this:
The XnView Shell extension, and according to the uninstaller, there are two XnViewMP programs. As far as I know, I only have one program installed. Is this supposed to be the case, or is there a faulty installation or update, which is why it says there are two programs installed?
Thanks.
jkm
Re: How many programs are listed as installed?
Post by jkm »
The 1.4.0 entry is from several years ago. It MIGHT be the remnants of an instance you installed in a different location, or the result of a partial uninstall, or some old registry entries, or a glitch, or anything because who knows how your unnamed 3rd party uninstaller is figuring things.
Once a Windows system has been used for a while, the registry is never clean. It’s the nature of the beast.
Use 3rd party uninstallers at your own risk.
Good luck…
SoCu
Post by SoCu »
Hi, I've never had any problems with uninstallers; in fact, I usually use one, and now I had to try another one, which is why I noticed the XnView entries.
Without one of these uninstallers, it wouldn’t be possible to uninstall some programs. For example, I installed a Wondershare program to test it, and then I wanted to uninstall it, but neither the program itself, nor Windows, nor the uninstaller I usually use could get rid of that darn Wondershare—and with this latest uninstaller, I was finally able to get rid of it.
Well, maybe it’s better to uninstall everything that appears there and reinstall it, and I think it would be better to use an uninstaller to remove all the registry data for those programs, because if I reinstall XnView, those entries would probably still show up.
