If select multiple thumbnails like 3 out of 10 in the folder then press Enter to go full screen view then use PageUp / PageDn buttons to switch next photo and previous photo i am limited to currently selected 3 pictures, not able to navigate across all images in the folder.
Is this bug or feature?
Full screen view limited to highlighted files
FKCapitalism2
jkm
Re: Full screen view limited to highlighted files
It’s a feature.
To quote Pierre from the guidelines pinned to the top of this board:
The fact that you're asking this question means you should not be posting this in the Bug Reports board.
If you aren't sure that you really found a bug, please post in "MP - General Support".
It's a feature
