v1.11.2 Info panel text wrong when panel shown on startup
Bugs which are supposed to be fixed in the next test version (not available yet)
FKCapitalism2
Post by FKCapitalism2 »
When XnViewMP is closed with info panel showing then panel would be shown on the next launch.
I closed panel in full screen and then double clicked the image in the windows explorer XnviewMP opened full screen however
  • text in Info panel is messed up.
  • 1-start rating icon is missing (but this might be separate bug as star rating is missing even if XnViewMP loads with info panel turned off)
After i closed info panel and opened it again using "I" hotkey text started showing normal.
Source file: https://www.upload.ee/files/19320072/DSC02625.zip.html
Re: v1.11.2 Info panel text wrong when panel shown on startup
