There's an issue with merging images
alee001
Post by alee001 »
Current Method:
1) The merged image enters edit mode instead of immediately.
2) After entering edit mode, you need to exit and save the file.
3) The saved image is not in the original path but in the currently used image folder.
4) The default name is strip_1.jpg, not the name of the merged image.
Suggested Method:
After clicking OK, the image will be saved immediately in the original path.
Horizontal merging is the default setting; vertical merging is optional.
