I downloaded XnView few days back and installed on my Linux m/c. It is a good viewer for managing digital images. However, I have some suggestions:
1. JPEG-lossless translations does not have any keyboard shortcut. Rotating an image is a frequent option. So maybe you should add a shortcut key. Also, it would be nice to have individual short cut keys for rotate 90 and rotate 270 degrees (Required a lot for flipping images from landscape mode to portrait mode).
2. Slide show improvements.
-- BUG: If the display image name is checked, it does not show the image name for the first image in slide show.
- Besides displaying image file name, it would be nice also to display date, time and any user comment during slide show.
- Currently, I am unable to add my own comments and description to Exif file format. May be instead of saving a description file, the description and comments should be stored in image header.
regards
navneet
Exif description and other suggestions
Re: Exif description and other suggestions
Ok, i'll check.navneet wrote:Hi,
I downloaded XnView few days back and installed on my linux m/c. It is a good viewer for managing digital images. However, I have some suggestions:
