OS: Windows - 64bit
Widgets swapped in Batch Convert -> Action -> Color Saturation.
Effect:
1. Color Saturation cannot be properly set in XnView or XnConvert.
2. Pressing Tab to set the next color randomly jumps.
I found it easier to record a video, side by side with GIMP. It shows first the color issue, and then the keyboard issue (both stemming from the same underlying problem).
Video: https://drive.google.com/file/d/1-RPQVv ... MXKJ8/view
Note: I tried installing also a 5 year old version of XnConvert from /old_versions/XnConvert/ (1.90.0), and it already had such issue.
Thank you for your attention!
