1.11.2 - edit EXIF - RAW - few issues
XnViewMP 1.11.2
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Edit EXIF
to reproduce
1. open folder with RAW files (eg ARW, CR2, DNG, NEF, RW2) in Browser
2. write some test data, eg
issue A
3. open 'Edit EXIF...' again
the following fields will be blank
they are not shown in EXIF tab as well, though they appear in ExifTool tab
  • arw, cr2, dng, nef, rw2
    - image description
    - document name
  • nef
    - artist field
    - copyright
  • rw2
    - software
    - artist
    - copyright
    - xp title
    - xp comment
    - xp autor
    - xp subject
    - orientation
issue B
incorrect tab order
- 'xp subject' is out of order when tabbing from 'xp autor'
- date fields, does not tab from date to reset/delete buttons
- date fields, does not tab anywhere from 'Not set' value
issue C
at some point app crashes leaving exiftool process in memory,
reopening folder with edited RAWs (and navigating out) cause crash
Re: 1.11.2 - edit EXIF - RAW - few issues
user0 wrote: Sat May 16, 2026 2:59 pm issue A
    - image description
    - document name
  • nef
    - artist field
    - copyright
  • rw2
    - software
    - artist
    - copyright
    - xp title
    - xp comment
    - xp autor
    - xp subject
    - orientation
It seems that Exiftool doesnt support fields for these format
issue C
are you able to reproduce?
