The "Find Similar Files" feature is excellent. I spent an entire weekend testing over a dozen similar software applications, and this one is by far the most satisfactory.
I do have a small suggestion, though.
Could the zooming mode for the "Find Similar Files" results be made consistent with the "compare" module? Specifically, using the mouse wheel alone would zoom all results synchronously, while holding Ctrl and using the mouse wheel would zoom only the image under the cursor.
Many thanks!
Find similar files: Results Synchronize Zoom with Mouse Wheel
zixjian
