Double clicking on a .webp file opens Xn View MP but it doesnt open the image. It works correctly for other files.
south-glint7
Post by south-glint7 »
Hello.
Every time I try opening a .webp file it opens Xn View MP but it acts like I just opened the program and it shows no image. This does not happen with the rest of the file formats in which the images are opened correctly. This is a bit annoying because sometimes I have to go and find the directory in with the webp file is stored and I may not know that.
Otherwise, I love Xn View MP.
Thank you very much for this program
Re: Double clicking on a .webp file opens Xn View MP but it doesnt open the image. It works correctly for other files.
south-glint7
Thank you for your reply. It didn't work, but I proceeded to uninstall XnView Mp, delete most of the keys from Regedit, reinstall and now it is working correctly.
Thank you!
