Subject: BUG: File Association tool fails on Windows 11 specifically for .jpg extension / "Open with" dialogue silently rejects XnViewMP.exe
XnView MP Version: 1.11.2 64 bit
Operating System: Windows 11 (64-bit)
I'm a loyal user to Xnview since I don't remember how long, this is the first time I fail to associate the extension to it, I digged a lot with the help of Gemini to reach this conclusion which worked for me. I then asked Gemini to generate this report to you to share my findings
## Description of Bug
The built-in system integration tool (Associate files with XnViewMP.exe) fails to apply file associations, even when explicitly run with Administrator privileges. It triggers the error message: “Problem to change file association. Please try to start with admin rights”.
This roadblock specifically targets the .jpg extension. Other standard image formats (such as .png, .gif, etc.) can be successfully assigned manually through the Windows 11 native Settings app (Settings > Apps > Default Apps > XnView MP). However, the .jpg format remains completely locked out. When attempting to resolve this by right-clicking a .jpg file and browsing directly to C:\Program Files\XnViewMP\XnViewMP.exe, the selection window silently disappears without applying the change, leaving the association stuck on a Microsoft default app like Photos or Paint.
## Steps to Reproduce
1. Install XnView MP via the standard 64-bit installer onto a current build of Windows 11.
2. Open Windows 11 Settings > Apps > Default Apps > XnView MP and assign extensions.
3. Observe that alternative extensions register smoothly, but .jpg fails to change.
4. Try running Associate files with XnViewMP.exe as an Administrator to force the change.
5. Result: The system triggers an administration privileges error.
6. Attempt a workaround by right-clicking a .jpg file > Open with > Choose another app > Choose an app on your PC and target the XnViewMP.exe binary.
7. Result: The dialogue window crashes/disappears silently, reverting back to Microsoft Photos or MS Paint.
## Technical Cause Analysis
Modern Windows 11 builds apply aggressive, hardened security locks to high-profile default extensions like .jpg to prevent malicious hijacking. Windows utilizes an internal UserChoice registry key tied to a unique security hash calculation. If the application binary name (XnViewMP.exe) attempts to claim this protected profile without full deployment in the modern Windows App Capabilities matrix, Windows 11 selectively blocks that specific file type and silently drops the execution path instruction.
## Working Solutions Found (For Developers' Reference)
Two targeted workarounds bypass this specific .jpg restriction:
* Solution A (The Executable Renaming Trick):
Renaming the executable binary from XnViewMP.exe to an unflagged name (e.g., ViewerX.exe) instantly bypasses the targeted Windows signature filter. The OS immediately allowed the renamed binary to be assigned as the permanent default handler for .jpg through the standard "Open with" dialogue.
* Solution B (System File Association Automation):
Bypassing the native "Default Apps" page entirely by deploying custom registry keys directly into HKEY_CLASSES_ROOT\SystemFileAssociations\.jpg\shell\. A batch file was successfully used to scale this context menu entry to all other supported image formats seamlessly.
## Suggestions for a Fix
Please update the application deployment script or installer to properly register XnView MP using the contemporary Windows Application Capabilities mapping under HKLM\SOFTWARE\RegisteredApplications. This will allow Windows 11 to recognize XnView MP as an authorized image platform handler specifically for highly guarded extensions like .jpg.
rawand
Re: File Association tool fails on Windows 11 specifically for .jpg extension / "Open with" dialogue silently rejects Xn
read this
XnViewMP - integration - file association
and do not use 'Associate files with XnViewMP.exe' in win10/11
rawand
Well, you didn't read my post completely, you just read the subject line.
1- XnviewMP failed to register the first time I installed it, it didn't appear in the add/remove Apps. so I reinstalled it to solve the issue.
2- It didn't assign itself automatically to the most used file types, I had to do it manually one by one, and when It came to *.jpg it refused to be assigned no matter what I try. nothing worked but the method I explained to you, which you didn't read.
If you want to dig into it, I'd gladly provide you with whatever info you'd need, otherwise, I solved the issue for myself, thank you very much.
