Color Labels and Ratings Disappeared
cgb1992
Hello! All my color labels and ratings have disappeared from XnView. I have the latest update and have not changed any settings lately. I was relying on labels to see what files I have to still work on and now that is all gone. I went through the forum to search for help but could not really find any solutions. Any help would be appreciated, thanks!
jkm
Re: Color Labels and Ratings Disappeared
Have you moved or renamed your files using a program other than XnViewMP? Like by using Windows Explorer, for example? If you do, that's what will happen.
(You should have the export checkbox for Color label checked as well, by the way.)
is it since the last update?
