After returning to the browser from full screen, Shift+left mouse button incorrectly uses the file from before full scre
faegagdagefs
After returning to the browser from full screen, Shift+left mouse button incorrectly uses the file from before full screen as the starting point for selection.
Re: After returning to the browser from full screen, Shift+left mouse button incorrectly uses the file from before full
I can reproduce
to reproduce
0. prerequisites
- have 5 files in folder
1. open folder in Browser, open 2nd image in fullscreen
2. navigate forward to the 4th image, close fullscreen mode (F11, middle click, Enter or Esc)
4th file is selected and has focus in filelist - OK
3. Shift+LMB click on 1st image
two images will be selected (1st and 2nd)
NOTE: there is 'Select file in Browser when Viewer tab is closed' setting (in Settings>Interface)
if state is:
☐ - Viewer file selection does NOT affect Browser selection/focus (default)
☑ - Viewer file selection DO affect Browser selection/focus, but the issue described above should be fixed
I would probably expect this setting to affect opening files in fullscreen from Browser as well
to reproduce
0. prerequisites
if state is:
