After new image added, the view automatically jumps to the end [Solved]
hiazzz
After new image is added to current view folder from outside the XnView, the view automatically jumps to the last image. I'm using sort by modified date desc.
jkm
Re: After new image added, the view automatically jumps to the end
Welcome to the forums...
You are seeing the effect of selectable behavior. Please adjust your settings in Tools->Settings:File List
You'll want to adjust "New Files are added at the end of the list" and "Auto-select new files" to suit your preference.
This is not a bug. Please only post in the bug report board when you're certain you have a bug.hiazzz wrote: Sun Jun 07, 2026 8:38 pm After new image is added to current view folder from outside the XnView, the view automatically jumps to the last image. I'm using sort by modified date desc.
hiazzz
thanks for your reply. after adjust the settings as you mentioned, XnView works great and as I expected.jkm wrote: Sun Jun 07, 2026 11:52 pm Welcome to the forums...
