When I try moving a video file, a message "Cannot remove source" pops up
baalexis
In XnViewMP, every time I try moving a video file to different location (alt+m) from the viewer mode I keep getting the message: "Cannot remove source". I tried stopping the video playback first. I also tried running as administrator. Nothing seems to work. Does anyone have this work for them? Am I doing it wrong? Thanks!
Re: When I try moving a video file, a message "Cannot remove source" pops up
is it working in browser mode?
baalexis
I double-checked. No, it does not work from the browser mode either.
do you use setting autoplay? Windows?
baalexis
Yes, I use the Autoplay setting. However, I tried turning it off and on again - nothing changes. I also tried simply stopping the video playback and moving the file - still the same result.
Yes, I use Windows 11.
i've sent you a PM
This problem is supposed to be fixed in XnView MP 1.11.6. Please check and confirm the bug fix here.
