OS: Windows 11 64bit 25H2 26200.8655
Despite not being noticeable when searching in a small amount of files, when searching in tens of thousands or more, new version is very slow. It would take minutes while old 1.9.5 takes within a minute.
Maybe it has something to do with Smart Album feature, because I tried 1.9.6, it was slow too.
1.11.2 Poor search performance, compared to 1.9.5 and earlier
gyoical
Re: 1.11.2 Poor search performance, compared to 1.9.5 and earlier
Search dialog? which criteria do you use?gyoical wrote: Fri Jun 12, 2026 10:24 am Despite not being noticeable when searching in a small amount of files, when searching in tens of thousands or more, new version is very slow. It would take minutes while old 1.9.5 takes within a minute.
gyoical
I search for files to convert like this pretty regularly:
The folder usually contains more folders, and each has not only images, but with html and other kinds of files alone side them.
Thank you.
Thank you.
ok, i've sent a PM
gyoical
Thanks for the help.
This problem is supposed to be fixed in XnView MP 1.11.4. Please check and confirm the bug fix here.
