How do I make the view NOT reset the zoom?
itisme
Post by itisme »
Hi.. just got a new laptop and installed the app again.. but I can not seem to work out what settings I used to have... basically I work on a lot of tony images (I'm a pixel artist).... I used to be able to load an image in the viewer... zoom in and then press space or the arrow keys to go to the next image in the sequence...BUT.. the size of the image in the window stays the same.. retaining the same zoom level... but no matter what I change in the view setting.. it seems to not actualy stop that from happening.. eveytime I press next the image sorta snaps to actual-size and is super small on screen again
TL;DR : What combination of settings allows me to zoom into a image in the viewer, and then when moving to the next image, the zoom level is remembered (so it dose not auto fit or display as actual size)
Re: How do I make the view NOT reset the zoom?
use No fit or Zoom lock
in Viewer>View>Zoom menu
