How to print a list of keywords
ChasZuck
Post by ChasZuck »
I really need to consolidate my keywords. Is there anyway to print a list of keywords used?
Re: How to print a list of keywords
Export Categories.. in Browser > Categories pane > Options🢓
ChasZuck
Post by ChasZuck »
Could you elaborate? I am not good at digging into the program, I need a thorough explanation.
KLE-France
Post by KLE-France »
On the menu bar: View > Panels > then check "Categories" if it's not already checked.
In the Categories panel: click on the dropdown menu (small, downward facing arrowhead) > Categories Management > click Export Categories...
Navigate to where you want to save the list, give it a name, and press OK.
Hope that helps and happy shooting to you.
ChasZuck
Post by ChasZuck »
Thank you MUCH! Saved your reply to my XnView notes.
