1.11.2 Creation date improperly modified on one local drive, but not the other
dave80
Post by dave80 »
The Creation Date/time of my photos is being improperly modified when I edit metadata or perform lossless operations.
Photos on my local drive C are unaffected.
Photos on my local drive D are affected.
I have tested this on both of my computers, both have the same problem.
Platform: Windows 10 Home 64bit.
XnView MP: 1.11.2
These are my Date/Time Settings.
When I add a star rating to a JPEG on local drive C, the creation date/time is not modified.
When I add a star rating to a JPEG on local drive D, the creation date/time is improperly modified immediately.
When I do a lossless rotate to a JPEG on local drive C, the creation date/time is not modified.
When I do a lossless rotate to a JPEG on local drive D, the creation date/time is improperly modified but only after navigating to another folder and back again, or exiting and reopening XnView MP.
Local drive C. Creation date/time not modified.
Local drive D Creation date/time improperly modified.
Re: 1.11.2 Creation date improperly modified on one local drive, but not the other
NTFS for the 2 drives?
jkm
Post by jkm »
Pierre, yes, he said NTFS for both drives.
Here is background on this issue.
viewtopic.php?p=214096#p214096
I could not reproduce it, of course, but neither could I find any cause. According to the user, drives are locally attached NTFS, no NAS.
If all the information provided by the OP is accurate, then it's a very strange issue.
dave80
Post by dave80 »
xnview wrote: Tue Jul 07, 2026 5:59 am NTFS for the 2 drives?
Yes Pierre, NTFS for both drives.
I have tried a clean install of XnView MP 1.11.5 but unfortunately the problem remains.
is it possible to execute these commands in a terminal?
fsutil 8dot3name query C:
fsutil 8dot3name query D:
dave80
Post by dave80 »
xnview wrote: Wed Jul 15, 2026 7:23 am is it possible to execute these commands in a terminal?
Certainly, here are the results.
The volume state is: 0 (8dot3 name creation is enabled).
The registry state is: 2 (Per volume setting - the default).
Based on the above settings, 8dot3 name creation is enabled on C:
The volume state is: 1 (8dot3 name creation is disabled).
Based on the above settings, 8dot3 name creation is disabled on D:
thanks, i've sent you a PM
dave80
Post by dave80 »
Thank you Pierre.
In case it helps, here are my Metadata settings.
dave80 wrote: Thu Jul 16, 2026 12:01 pm In case it helps, here are my Metadata settings.
i've sent you a PM
This problem is supposed to be fixed in XnView MP 1.11.6. Please check and confirm the bug fix here.
