NConvert with latest plugins
herb
Post by herb »
Hello Pierre,
I just installed XnViewMP 1.11.4. Thanks for this new version.
Looking into (sub)directory plugins I have seen that almost all *.dll files are enhanced to latest versions and openEXR files have another filename.
Can we have NConvert_unicode.exe that also works with these "new" plugins.
Thanks in advance.
Best regards
herb
Re: NConvert with latest plugins
could you try this version
herb
Post by herb »
Hello Pierre,
thanks for the new version 7.240.
I started the tests, but please be aware I have not finished.
Here are 2 comments
- with gpr.dll also *.gpr files can be converted. Please add this dll to plugins
- *.exr file can be converted using the "old" dll files (with "3-2" in filename).
I hoped that the new version will be working with the enhanced exr dll file (with "3-4" in filename)
Thanks again
Best regards
herb
herb wrote: Wed Jul 01, 2026 11:06 am - *.exr file can be converted using the "old" dll files (with "3-2" in filename).
it doesnt work with latest exr dll?
herb
Post by herb »
Hello Pierre,
xnview wrote: Wed Jul 01, 2026 11:23 am it doesnt work with latest exr dll?
For me the latest exr dll have all "3-4" in filename.
This was my mistake. Also Imath-3_2.dll (with "3-2" in filename) must be available.
So it works now for exr file.
I will continue my tests.
Best regards
herb
herb
Post by herb »
Hallo Pierre,
during my test I found that XnViewMp 1.11.5 does not display all *.psd images and also NConvert 7.240 does not convert it to *.jpg
(see: viewtopic.php?t=50936).
I also found that NConvert does not convert *.ora images. The libora.dll is available plugins directory.
But XnViewMP 1.11.5 does display my testfile.
I get the following:
Error: Can't open file () ( 4 times)
I will send the testimage via mail.
Best regards
herb
herb
Post by herb »
Hello Pierre,
Problems also occure with *.dds files.
They are converted properly - BUT NConvert does NOT send the message (to stderr)
Converion of ... into ... OK
And also with *.xpm images.
NConvert gives the following error message:
Error: This picture cannot be written using this format <path-to-jpg-image>
But XnViewMP does this file store in jpg format without any problems.
Best regards
herb
herb wrote: Fri Jul 03, 2026 12:34 pm I also found that NConvert does not convert *.ora images. The libora.dll is available plugins directory.
it works here, libora (295 936 bytes) from XnViewMP?
always?
which command line?
herb
Post by herb »
Hello Pierre,
thanks for your quick reply and thanks for taking time looking into my problems.
(1) @ *.ora files
Here I have to say sorry. I regret, but it was an error in my application that caused the problem.
(2) @ *.dds files
It is hard to answer your question because my test-file collection contains only 1 *.dds image.
Please find this image attached.
(3) @ *.xpm files
I mostly use NConvert with my application. It uses the following generic commandline
-ignore_errors -page 0 -overwrite -out jpeg -q 100 -o <path to outputfile without any space> <path to source file in quotes>
I hope my answers help a little bit.
Best regards
herb
please send me the xpm too?
herb
Post by herb »
Hello Pierre,
attached please find my xpm testfile.
Best regards
herb
it's an indexed color picture, so you need -32bits
herb
Post by herb »
Hello Pierre,
thanks for your analysis.
I thought it is an error in NConvert, because XnViewMP 1.11.5 and also IrfanView can read the image and store as *.jpg image.
Is there any chance that also NConvert can store it as jpg.
Please keep in mind that I am looking for a generic command to be used for all formats.
xnview wrote: Sun Jul 05, 2026 4:16 pmyou need -32bits
What does this mean in detail?
Is it option -32bits?
If yes, can this option be used as part of a generic command?
Best regards
herb
-32bits convert in RGB/RGBA the picture, the only problem is if you have a 8bits grey image
so no new problems?
