Batch Rename in 1.11.4 doesn't sort like Browser
laurent45654
Post by laurent45654 »
Let's say I have a folder of files:
Sorted by name.
Then I manually move 01.png to get this:
Then call batch rename on this to rename them all ##.png.
I expect this:
That's how all previous version of XnView have been working, and it seems logical to me. But in 1.11.4 I get this instead:
So somehow it starts with the latest file. I thought I was going crazy initially, with all my batch renames being flipped around but I can replicate it consistently. Is that a known bug?
jkm
Re: Batch Rename broken in latest version
Post by jkm »
"Broken" is not a good title for this. It has a bug, minor enough some people might not notice.
I can reproduce a bug, but it does not agree with your example.
In 1.11.2, the Batch Rename honored the sorting order in the Browser. In 1.11.4, it does NOT honor the sorting order in the Browser, and instead seems to always impose Alphabetic Descending. :bug:
In your example, in order for this
laurent45654 wrote: Sun Jun 28, 2026 1:54 pm Then I manually move 01.png to get this:
to be true, you must be using Custom Sort in the Browser.
If I use custom sort to produce this order:
Then Batch Rename in 1.11.2 shows:
(This is the old behavior, which you wanted, and which I agree is appropriate.)
But 1.11.4 shows THIS: (100% of the time)
It doesn't "start with the latest file". It imposes Alphabetic Descending sort, regardless of the sort order in the browser. Changing to any non-custom sort in the Browser doesn't matter. Batch Rename always imposes Alphabetic Descending.
So are you sure your example you posted above is correct? Maybe provide a screenshot.
I see a bug, but not exactly the behavior you're reporting.
I've created a bug report.
laurent45654
Right, that's indeed what I observed now that I think about it. Well broken or buggy I don't know, but not usable as it is
jkm
Post by jkm »
laurent45654 wrote: Sun Jun 28, 2026 8:00 pm but not usable as it is
To you. Not for lots of people.
It’s perfectly usable for anyone who needs an alphabetic sort, which is the default of the browser anyway. That’s why I said some people might not even notice as an issue what you consider to be unusable.
This bug has been fixed in 1.1.5 which is now available.
Misha Khazov
Re: Batch Rename in 1.11.4 doesn't sort like Browser
Post by Misha Khazov »
That is very important feature for me, thanks for fixing the bug!
