In 1.11.4, it does NOT honor the sorting order in the Browser, and instead seems to always impose Alphabetic Descending.
If I use custom sort to produce this order:
Then Batch Rename in 1.11.2 shows:
But 1.11.4 shows THIS: (100% of the time)
It imposes Alphabetic Descending sort, regardless of the sort order in the browser.
Changing to any non-custom sort in the Browser doesn't matter. Batch Rename always imposes Alphabetic Descending.
You can click the Name header to change between Alphabetic Descending and Ascending, but that is useless if you need some other sort order.
Expected Behavior: Batch Rename dialog should honor the sort order of the Browser, like it did in 1.11.2.
