XnView: MP 1.11.5 64 bit
OS: Windows 64bit
I have had my mouse click configuration set so that right button is next file, left is previous. I think one or two versions ago a menu started to appear when right-clicking as well as going to the next file. That's happening with whatever you configure the right button to do now as far as I can tell.
Effect: A window pops up and block the view of the image.
1. Configure mouse right click with no modifier to show next file
2. Right click on an image to go to the next one
Actual behaviour (bug): A menu window pops up in addition to going to the next file.
Expected behaviour: Going to the next file, nothing more. I guess the menu should only appear when mouse right click is set to "do nothing".
1.11.5 Right-click configuration always pops up a menu
Egera
jkm
Re: 1.11.5 Right-click configuration always pops up a menu
Confirmed, this behavior has changed from 1.11.2.
Context menu should not appear on a R-Click if R-Click is set to next/previous image.
In 1.11.2, if R-Click was set to Next file, the Context menu was completely inhibited; it would never appear.
But I think that is bad behavior as well, since the Context menu can be essential.
I think the best solution is if R-Click is set to previous/next file, then the Context menu should only appear on R-Click HOLD. (more than a second)
All other options require a drag, and don't have a context menu problem. So for all other options, R-Click should continue to bring up the context menu as it currently does.
same issue with LMB - selection stops working if set to navigation
it is better to:
- split 'No modifier' into Click (single) and Hold in LMB,RMB groups
- add explicit 'Context menu' action
- rename 'No modifier' accordingly in Middle button and Wheel groups
it is better to:
