Pan/Tilt with mouse
osado
Pan/Tilt with mouse
Post by osado »
Don't know if someone else requested it before me, but I'd like the feature in other picviewers to use your mouse to pan/tilt in a picture which is bigger than screen or when you've zoomed in so it is bigger than screensize (mouse cursor becomes a hand).
ACDSee and FastStone has got this feature.
Good work so far Pierre!
Thanks!
Re: Pan/Tilt with mouse
osado wrote:Don't know if someone else requested it before me, but I'd like the feature in other picviewers to use your mouse to pan/tilt in a picture which is bigger than screen or when you've zoomed in so it is bigger than screensize (mouse cursor becomes a hand).
Thanks!
Ok, yes a good feature...
osado
Post by osado »
xnview wrote: Ok, yes a good feature...
Really? :) Cause I just found out it's already built-in! When clicking rightmouse it gives the hand :D
Close this topic! :P
Dreamer
Post by Dreamer »
You can even change it to left mouse button.
Closed.
