It's nice to see the app working better and better.
And now my next notes:
1. The "startup view" option has a bug. Selecting "Last used" remembers the view option you just set. After killing the application, instead of the actual last used view, it initially shows the view when this option was selected.
2.
As for the "bookmark folder", I didn't notice this option. Still, I would see this option as showing "favorite folders" like an Albums, rather than a drop-down selection list. At least it seems more natural to me.
3. When I click on the hamburger (three lines on the top left) and do not select anything, after clicking the system "undo" icon, it closes the application instead of just closing the display of this tab. This works correctly when clicking the icon below (sorting options).
4. There is an error when displaying photos. Specifically, when there are a large number of files, when you slowly scroll down or up,
then a brown stripe and a spinning circle suddenly appear on the border of the photos. This brown stripe may also flicker.
5. I have several jpg files in the "Screenshots" folder, but the application only displays one old one, taken with another phone. The file I made as a test did not appear. The uploaded photo, which is visible in the Gallery, does not appear either.
6. When selecting is "Folders" I noticed three folders (created by me), one that shows up twice and the other three times. They don't show the correct number of files, but the total is correct. Only when I click the first one, it shows all the photos correctly. Clicking on these next shows emptiness. "Albums" works properly.
Android app 24/06 - test 2
Re: Android app 24/06 - test 2
Thanks
Please make one post per bug/suggestion
ok, which preview view (before killing it) do you have?1. The "startup view" option has a bug. Selecting "Last used" remembers the view option you just set. After killing the application, instead of the actual last used view, it initially shows the view when this option was selected.
So something like 'Image favorite' and 'folder favorite'?2.
right3. When I click on the hamburger (three lines on the top left) and do not select anything, after clicking the system "undo" icon, it closes the application instead of just closing the display of this tab. This works correctly when clicking the icon below (sorting options).
yes right4. There is an error when displaying photos. Specifically, when there are a large number of files, when you slowly scroll down or up,
could you send me a sample file?5. I have several jpg files in the "Screenshots" folder, but the application only displays one old one, taken with another phone. The file I made as a test did not appear. The uploaded photo, which is visible in the Gallery, does not appear either.
when you use 'Folders'? please send a screenshot6. When selecting is "Folders" I noticed three folders (created by me), one that shows up twice and the other three times. They don't show the correct number of files, but the total is correct. Only when I click the first one, it shows all the photos correctly. Clicking on these next shows emptiness. "Albums" works properly.
Kadet
After many tests now I know – it doesn't work for: Camera, Downloads, Screenshots and Ratings.xnview wrote: Fri Jul 03, 2026 5:01 pmok, which preview view (before killing it) do you have?1. The "startup view" option has a bug. Selecting "Last used" remembers the view option you just set. After killing the application, instead of the actual last used view, it initially shows the view when this option was selected.
Yes. 'Favorites' rename for 'image favorite' and add FF.So something like 'Image favorite' and 'folder favorite'?2.
I already know where the problem is. Well, I had two 'Screenshots' folders on my phone: one in DCIM and the other in Pictures. Olny the first one was displayed. This was probably due to changing phones and copying pictures. On this current phone, SS went to the other one. After deleting the first folder, it now displays fine.could you send me a sample file?5. I have several jpg files in the "Screenshots" folder, but the application only displays one old one, taken with another phone. The file I made as a test did not appear. The uploaded photo, which is visible in the Gallery, does not appear either.
Gallery merge folders with same name (no case), but if you enter in second 'imprezy' or 'Imprezy' no images?
Kadet wrote: Fri Jul 03, 2026 7:56 pmScreenshot_2026-07-03.jpgwhen you use 'Folders'? please send a screenshot6. When selecting is "Folders" I noticed three folders (created by me), one that shows up twice and the other three times. They don't show the correct number of files, but the total is correct. Only when I click the first one, it shows all the photos correctly. Clicking on these next shows emptiness. "Albums" works properly.
Kadet
No images. This is only one folder „Imprezy”! And is only one folder „Inne”.
Update: In the new version all work ok.
