Feature request: more columns for grid view [Fixed]
masterjp
I really like the grid view because it gives you a quick overview of your photos. For smartphones, I find a grid view with 2 to 3 columns to be perfectly sufficient. On my tablet or Android TV box, 3 columns is a bit too few. So it would be great if the number of columns could be customized up to 6 for tablets (2560x1080 pixels) and up to 10 columns for Android TV boxes (1920x1080 pixels).
Kadet
Re: Feature request: more columns for grid view
You must have an older test version, because in the newer one that I received from Pierre yesterday, you can set a maximum of 8 columns. I had the same comment about the previous version and it was taken into account, although I suggested that it could be possible to set up to 16 columns.
masterjp
You are right. Thank you. I downloaded the apk from kdrive again and get the latest version. Fantastic.
