Custom Rating Label cannot be changed back to default
Bugs which are supposed to be fixed in the next test version (not available yet)
jkm
Post by jkm »
In 1.11.5, custom Rating Labels can be assigned, but they cannot be "unassigned" and subsequent edits require a restart.
There are two bugs:
:bug: Once a Rating Label has been edited, the default text will no longer be accepted.
:bug: When a Rating Label has been edited, some UI elements update immediately, but others require a restart.
Steps to reproduce:
Start with defaults.
0. Observe default label for 1-star is Poor
1. Set label for 1-star to Bad
2. Click OK
3. Observe that on Rating overlay in browser, 1=Bad, but on menu Metadata->Set Rating, 1=Poor :bug: Restart required
4. Restart app
5. Observe that on menu Metadata->Set Rating, 1=Bad (now correct after restart)
6. Set label for 1-star to Poor (this is setting it back to default)
7. Click OK
8. Check Tools->Settings:Rating Labels
9. In the dialog, 1 is still set to Bad. The value Poor is not accepted, and will not be saved. :bug:
The only way to reset rating labels to the default values is to manually edit or delete the ratingLabel line in the INI file.
Re: Custom Rating Label cannot be changed back to default
Yes, changing rating/color labels need restart...
About the bug, you are able to reproduce each time?
jkm
Post by jkm »
xnview wrote: Sun Jul 05, 2026 2:48 pm Yes, changing rating/color labels need restart...
But only partially. User should be warned, like with changing theme.
xnview wrote: Sun Jul 05, 2026 2:48 pm About the bug, you are able to reproduce each time?
Yes.
